karlblomquist
Dec 21, 2011Aspirant
case:17437017 NVX 4 x 3TB = only 7408GB. Should be 8100+GB?
I recently expanded drives on one of our NVX systems to 4 3TB drives. Raidar shows each drive being 2794GB in size. However we are only getting 7408GB total usable space on the system - it s...
PapaBear1
Dec 23, 2011Apprentice
An OS reinstall will reset the password and configuration, but is not supposed to affect data in any way. Of course, as you pointed out Murphy is always lurking. I have never had a problem with an OS reinstall or upgrade, but probably because I keep Murphy at bay with a complete an current backup.
