RupertGiles
Jun 02, 2020Apprentice
Catalina, Time Machine, and my ReadyNAS
I thought I'd share my recent experience with Time Machine and my ReadyNAS 314. I finally took the plunge, and upgraded my Mac from Mojave to Catalina. Suprisingly, the upgrade went off without inci...
RupertGiles
Jul 18, 2020Apprentice
Are you issuing the extended directory command?
"." files don't appear unless you type:
ls -al
After logging in, try (if you haven't already) type:
cd /data/.timemachine
Here, you should see either a single entry for ReadyNAS or an entry for each user/machine that you're backing up. If you don't have a /data/.timemachine directory entry, then I'd be at a loss to tell you where to look. Perhaps ReadyNAS configures multiple machines differently than just a single machine like mine.
Greg
twolcrazy
Jul 19, 2020Tutor
Greg,
Yes I am using ls -al. There is no /data directory. I have looked through all the others, most of which appear to be standard linux directories. There is one directory that contains our shared files but there are no time machine directoried or files in that one. Thus I have not been able to locat anything that looks like time machine.
John
