beefybarn
Sep 29, 2014Aspirant
Changing disc on a 104
Hi I am running a rn104 with 3x3tb and 1x2tb drives in raid 5. I have just got another 3tb drive, can I just pull the 2tb and replace it with the 3tb and let the volume rebuild, also can I hot swap...
Sep 29, 2014Guru - Experienced User
I always prefer hot-swapping, since then the NAS has a clear indication of removal/insertion
So you can simply remove the 2 TB drive with the NAS running, install the new drive into the same tray, and then hot-insert.
Also, it is always a good idea to update backups before manipulating the disk drives in the RAID array.
