beefybarn
Sep 29, 2014Aspirant
Changing disc on a 104
Hi I am running a rn104 with 3x3tb and 1x2tb drives in raid 5. I have just got another 3tb drive, can I just pull the 2tb and replace it with the 3tb and let the volume rebuild, also can I hot swap...
vandermerwe
Nov 09, 2014Master
You said you had tested the drive when I asked, are you saying it passed your initial testing and failed on subsequent testing?
Testing a drive should use vendor tools extended or long tests, shorter tests have false negatives.
