Chokehold
May 18, 2016Aspirant
Changing from Flex-RAID to X-RAID
I was casually looking at the volumes tab of my ReadyNAS admin page. And so I noticed that the X-RAID button was not lit. I specifically recall getting a ReadyNAS specifically for X-RAID capabilitie...
- May 19, 2016
Your logs show a 4x2TB RAID-5 layer and a 3x2TB RAID-5 layer. Replace the 3TB disk with a 4TB disk and you should get some more expansion.
May 18, 2016Guru - Experienced User
If you are running RAID-5 with a single volume then you should be able to switch to xraid with no data loss.
What is your current disk configuration? Are all the disks the same size?
Chokehold
Sadly they are not the same size.
It is currently RAID-5 with Flex-RAID, like so in this order from left to right in the bays:
WDC WD30EZRX-00D8PB0 3TB
WDC WD40EFRX-68WT0N0 4TB
