Chokehold
May 18, 2016Aspirant
Changing from Flex-RAID to X-RAID
I was casually looking at the volumes tab of my ReadyNAS admin page. And so I noticed that the X-RAID button was not lit. I specifically recall getting a ReadyNAS specifically for X-RAID capabilitie...
- May 19, 2016
Your logs show a 4x2TB RAID-5 layer and a 3x2TB RAID-5 layer. Replace the 3TB disk with a 4TB disk and you should get some more expansion.
Chokehold
Sadly they are not the same size.
It is currently RAID-5 with Flex-RAID, like so in this order from left to right in the bays:
WDC WD30EZRX-00D8PB0 3TB
WDC WD40EFRX-68WT0N0 4TB
May 18, 2016Guru - Experienced User
This is not a problem, it simply suggests that XRAID is a better mode for you.
You can turn XRAID on. I haven't tried that in this scenario, so I am not sure if the volume will automatically expand when you do. So let us know. If it doesn't immediately expand, try rebooting.
jak0lantash wrote:
Also, please, if you're unsecure, have an external backup of your data!
The truth is, you should feel concerned if you don't have a backup. Your data is always at risk if it is only stored on one device. Raid reduces that risk some, but it is still there.
