isaacl
Sep 05, 2013Aspirant
Changing Netgear DUO from Raid 0 to Raid 1
Hi, I have a Netgear DUO v1 Currently in Raid 0, 2x2TB HD (4TB). I would like to make it into Raid 1. I know this is impossible to convert as Raid 0 is stripped and Raid 1 is mirrored. What I would...
Sep 05, 2013Guru - Experienced User
Since you are using flex-raid you should be able to destroy the existing RAID volume, and then create a new one that uses RAID-1. This should not require a factory reset, so your add-ons, user accounts, etc. would not be affected. Of course you would need to recreate the shares, and restore the data.
