xeltros
Jan 22, 2014Apprentice
Cisco firewall before RN104.
Hi guys, I know this forum is for readyNAS but I struggle configuring CISCO NAT to provide external access to my ReadyNAS. I was wondering if someone could be of some help here. I bought a cheap s...
xeltros
Feb 10, 2014Apprentice
For the firewall, yes my usage is pretty basic I am to use HTTP(S)/(s)FTP/SSH mainly, maybe a little bit of DNS. I will also need the VPN (L2TP/IPSec on the router) to pass through. Anything more evolved than that will be filtered via VPN credentials only (once connected you get full access). I'd just like to filter a little bit and practice Cisco doing it. I'm giving up the IPS feature because having a second hand router I don't have the account it was registered with and the router's memory/CPU is limited but would have been nice.
I'm testing out the NAS command from this conf (the same you already read except I added description to interfaces and with no NAT except inside/outside int definitions)
I'll send raw results to avoid any error from my side.
IP NAT detailed debugging is on (activated after sending the conf)
I do a full router reload between each configuration to be sure to start on the clean conf above.
With no NAT (witness config)
I will only be testing NAT on the other configs, since basic IP shouldn't be disturb much by NAT only.
FROM ROUTER :
ping 192.168.0.1 (internet gateway) => OK
ping 172.16.0.200 (NAS eth1) => OK
FROM MAC (having a static route to 172.16.0.200(NAS eth1) via 192.168.0.10 (Router FA0)
=> ping 172.16.0.200 => OK
=> ping 192.168.0.10 => OK
=> ping 172.16.0.254 => OK (router vlan 172)
=> web interface 172.16.0.200 => OK
=> web interface 192.168.0.10 => TIMEOUT
NAT INSIDE (the one I already posted)
Web interface (192.168.0.10) => TIMEOUT
router output :
NAT OUTSIDE
using command ip nat outside source static tcp 192.168.0.10 60443 172.16.0.200 443 extendable
router output :
NAT OUTSIDE BIS
using command ip nat outside source static tcp 172.16.0.200 443 192.168.0.10 60443 extendable
router output :
NAT INSIDE BOTH WAYS
ip nat inside source static tcp 172.16.0.200 443 192.168.0.10 60443 extendable
ip nat inside source static tcp 192.168.0.10 60443 172.16.0.200 443 extendable
router output :
NAT address to address
command ip nat inside source static 172.16.0.200 192.168.0.10
*Jan 21 08:56:03.379: ipnat_add_static_cfg: id 3, flag 6
*Jan 21 08:56:03.379: id 3, flags 0, domain 0, lookup 0, from_addr AC1000C8, from_mask FFFFFFFF, from_port 0, to_addr C0A8000A, to_port 0 to_mask FFFFFFFF, proto 0
*Jan 21 08:56:03.383: NAT: installing alias for address 192.168.0.
kerberos(config)#do sh ip nat tra
Pro Inside global Inside local Outside local Outside global
--- 192.168.0.10 172.16.0.200 --- ---
(while pinging 192.168.0.10 from MAC (ping OK))
kerberos(config)#
*Jan 21 08:56:25.847: NAT*: o: icmp (192.168.0.26, 56136) -> (192.168.0.10, 56136) [4938]
*Jan 21 08:56:25.847: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [4938]
*Jan 21 08:56:26.847: NAT*: o: icmp (192.168.0.26, 56136) -> (192.168.0.10, 56136) [39977]
*Jan 21 08:56:26.847: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [39977]
NAT address to address with 192.168.0.11
command : ip nat inside source static 172.16.0.200 192.168.0.11
None of the config got me to access the web interface, but as far as I can judge with ip nat inside anything goes well on the router... (PS when there is no debug in NAT, that means NAT wasn't triggered, I copied the output I got).
Because everything seems fine to me, I wondered if I should set a route, but the router is directly connected it knows where to send anything. Moreover when accessing 172.16.0.200 telling my MAC to route via 192.168.0.10 it works so I don't see any reason this wouldn't work while doing NAT...
Xel
Building configuration...
Current configuration : 1526 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname kerberos
boot-start-marker
boot-end-marker
enable secret 5 SECRET
aaa new-model
aaa session-id common
ip cef
no ip domain lookup
ip domain name kerberos.mydomain.fr
multilink bundle-name authenticated
username xeltros secret 5 SECRET
archive
log config
hidekeys
ip ssh version 2
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
description INTERNET (bad guys)
ip address 192.168.0.10 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
description VLAN10 (VPN) dedicaced interface
switchport access vlan 10
interface FastEthernet2
description VLAN172 (DMZ) dedicaced interface
switchport access vlan 172
interface FastEthernet3
interface FastEthernet4
interface Vlan1
no ip address
interface Vlan10
description future VPN (good distant guys)
ip address 10.0.0.254 255.255.255.0
ip nat inside
interface Vlan172
description DMZ (good protected guys)
ip address 172.16.0.254 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0
ip route 0.0.0.0 0.0.0.0 192.168.0.1
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
transport input ssh
end
FROM ROUTER :
router output :
kerberos#sh ip nat tra
tcp 192.168.0.10:60443 172.16.0.200:443 --- ---
kerberos#
*Jan 21 08:29:37.591: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [47325]
*Jan 21 08:29:37.595: NAT*: TCP s=54949, d=60443->443
*Jan 21 08:29:37.595: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [47325]
*Jan 21 08:29:37.735: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [56852]
*Jan 21 08:29:37.735: NAT*: TCP s=54949, d=60443->443
*Jan 21 08:29:37.735: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [56852]
*Jan 21 08:29:37.935: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [46679]
*Jan 21 08:29:37.939: NAT*: TCP s=54949, d=60443->443
*Jan 21 08:29:37.939: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [46679]
*Jan 21 08:29:38.139: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [59982]
*Jan 21 08:29:38.139: NAT*: TCP s=54949, d=60443->443
*Jan 21 08:29:38.139: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [59982]
*Jan 21 08:29:38.339: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [27074]
*Jan 21 08:29:38.339: NAT*: TCP s=54949, d=60443->443
*Jan 21 08:29:38.339: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [27074]
*Jan 21 08:29:38.543: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [14430]
*Jan 21 08:29:38.543: NAT*: TCP s=54949, d=60443->443
*Jan 21 08:29:38.543: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [14430]
*Jan 21 08:29:38.843: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [748]
*Jan 21 08:29:38.843: NAT*: TCP s=54949, d=60443->443
*Jan 21 08:29:38.843: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [748]
*Jan 21 08:29:39.343: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [38102]
*Jan 21 08:29:39.343: NAT*: TCP s=54949, d=60443->443
*Jan 21 08:29:39.343: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [38102]
*Jan 21 08:29:40.247: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [40722]
*Jan 21 08:29:40.247: NAT*: TCP s=54949, d=60443->443
*Jan 21 08:29:40.247: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [40722]
*Jan 21 08:29:42.055: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [59666]
*Jan 21 08:29:42.055: NAT*: TCP s=54949, d=60443->443
*Jan 21 08:29:42.055: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [59666]
*Jan 21 08:29:45.711: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [18061]
*Jan 21 08:29:45.715: NAT*: TCP s=54949, d=60443->443
*Jan 21 08:29:45.715: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [18061]
*Jan 21 08:29:52.391: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [15853]
*Jan 21 08:29:52.391: NAT*: TCP s=54949, d=60443->443
*Jan 21 08:29:52.391: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [15853]
*Jan 21 08:29:59.191: NAT*: o: tcp (192.168.0.26, 54949) -> (192.168.0.10, 60443) [26239]
*Jan 21 08:29:59.191: NAT*: TCP s=54949, d=60443->443
*Jan 21 08:29:59.191: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [26239]
tcp 192.168.0.10:60443 172.16.0.200:443 192.168.0.26:54949 192.168.0.26:54949
kerberos#
*Jan 21 08:30:59.211: NAT: expiring 192.168.0.10 (172.16.0.200) tcp 60443 (443)
NAT OUTSIDE
router output :
*Jan 21 08:40:00.251: ipnat_add_static_cfg: id 2, flag 6
*Jan 21 08:40:00.251: id 2, flags 0, domain 1, lookup 1, from_addr C0A8000A, from_mask FFFFFFFF, from_port EC1B, to_addr AC1000C8, to_port 1BB to_mask FFFFFFFF, proto 6
*Jan 21 08:40:00.255: NAT: installing alias for address 172.16.0.200
tcp --- --- 172.16.0.200:443 192.168.0.10:60443
NAT OUTSIDE BIS
router output :
*Jan 21 08:52:43.003: ipnat_add_static_cfg: id 2, flag 6
*Jan 21 08:52:43.003: id 2, flags 0, domain 1, lookup 1, from_addr AC1000C8, from_mask FFFFFFFF, from_port 1BB, to_addr C0A8000A, to_port EC1B to_mask FFFFFFFF, proto 6
*Jan 21 08:52:43.007: NAT: installing alias for address 192.168.0.10
tcp --- --- 192.168.0.10:60443 172.16.0.200:443
router output :
tcp 172.16.0.200:443 192.168.0.10:60443 --- ---
kerberos(config)#
*Jan 21 08:46:59.723: NAT*: o: tcp (192.168.0.26, 55025) -> (192.168.0.10, 60443) [56183]
*Jan 21 08:46:59.727: NAT*: TCP s=55025, d=60443->443
*Jan 21 08:46:59.727: NAT*: s=192.168.0.26, d=192.168.0.10->172.16.0.200 [56183]
*Jan 21 08:46:59.727: NAT: i: tcp (172.16.0.200, 443) -> (192.168.0.26, 55025) [44274]
*Jan 21 08:46:59.731: NAT: TCP s=443->60443, d=55025
*Jan 21 08:46:59.731: NAT: s=172.16.0.200->192.168.0.10, d=192.168.0.26 [44274]
tcp 192.168.0.10:60443 172.16.0.200:443 192.168.0.26:55025 192.168.0.26:55025
kerberos(config)#
*Jan 21 08:58:54.867: ipnat_add_static_cfg: id 5, flag 6
*Jan 21 08:58:54.867: id 5, flags 0, domain 0, lookup 0, from_addr AC1000C8, from_mask FFFFFFFF, from_port 0, to_addr C0A8000B, to_port 0 to_mask FFFFFFFF, proto 0
*Jan 21 08:58:54.867: NAT: installing alias for address 192.168.0.11do sh ip nat tra
--- 192.168.0.11 172.16.0.200 --- ---
(while pinging 192.168.0.11 from MAC, ping OK)
kerberos(config)#
*Jan 21 08:59:31.347: NAT*: o: icmp (192.168.0.26, 24137) -> (192.168.0.11, 24137) [29439]
*Jan 21 08:59:31.351: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [29439]
While accessing web interface (192.168.0.11, TIMEOUT)
*Jan 21 09:03:59.871: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [18909]
*Jan 21 09:03:59.871: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [18909]
*Jan 21 09:04:00.871: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [22728]
*Jan 21 09:04:00.871: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [22728]
*Jan 21 09:04:01.875: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [5438]
*Jan 21 09:04:01.879: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [5438]
*Jan 21 09:04:02.883: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [64158]
*Jan 21 09:04:02.883: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [64158]
*Jan 21 09:04:03.887: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [16652]
*Jan 21 09:04:03.887: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [16652]
*Jan 21 09:04:04.891: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [47748]
*Jan 21 09:04:04.895: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [47748]
*Jan 21 09:04:06.907: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [42904]
*Jan 21 09:04:06.907: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [42904]
*Jan 21 09:04:10.927: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [50389]
*Jan 21 09:04:10.927: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [50389]
*Jan 21 09:04:18.935: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [33094]
*Jan 21 09:04:18.935: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [33094]
*Jan 21 09:04:34.967: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [50797]
*Jan 21 09:04:34.971: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [50797]
*Jan 21 09:05:07.075: NAT*: o: tcp (192.168.0.26, 55067) -> (192.168.0.11, 80) [61870]
*Jan 21 09:05:07.075: NAT*: s=192.168.0.26, d=192.168.0.11->172.16.0.200 [61870]
Xel
