rhiangil
Dec 18, 2013Follower
Clearly too stupid to own a NAS
Hi all, Just wondering if I should give my NAS to someone here? I had my ReadyNAS NV+ v2 start to warn me of disk errors and possible failure a few days back. Thought I'd purchase a WD 4TB Red t...
mdgm-ntgr
Dec 18, 2013NETGEAR Employee Retired
The NAS worked as designed. You hot-added a disk (added a disk while the NAS was on) and the NAS wiped the newly added disk.
The OS is stored on all the disks. The NAS will wipe disks that are hot-added automatically, create the necessary partitions and mirror the OS.
You should be able to power down, remove all disks (including both the 4TB disk and the wiped disk) and put your remaining good disks only in the NAS and see the data on them.
As for the disk that was wiped your data is most likely gone, especially if it is large files like video. Though since it's a single disk you could still try data recovery software.
When in doubt about something like what adding a disk will do, ask first. And now that you are feeling the pain of data loss consider backing up your important data in future. No important data should be entrusted to a single device.
