kturcotte
Sep 06, 2014Aspirant
Clients aren't seeing both drives
I have a ReadyNAS Ultra 6. I have 2 3 TB hard drives installed, with various video files on both drives. The NAS is connected directly to my router, and so is my PS3 and Western Digital Tv Live Hub. B...
Sep 06, 2014Guru - Experienced User
ES File Explorer doesn't have a "default". You choose the protocol when you add the device. If you pick "LAN" you are using SMB/CIFS.
WDTV has two options. If you select "mediaserver" you are using DLNA. If you select "network shares" you are using SMB/CIFS.
My guess is that you are using DLNA with the PS3 and the WDTV - and that you perhaps haven't entered all the shares you want DLNA to scan. That would be under services->streamservices.
Either way, if DLNA is enabled click on the "rescan media files" control. BTW, personally I think "network shares" is a better way to go with the WDTV.
