pl_shibby
Aug 06, 2019Aspirant
Collabora Online stopped working after upgrade firmware to 6.9.3 and newer
I`m currently using firmware 6.9.2 on my Readynas Pro4. Everything works fine. I`m using Owncloud 10 with Collabora Online 6.0. But after upgrade ReadyNAS firmware to newer version (6.9.3, 6.9.5, al...
- Aug 11, 2019
FYI update to OS 6.10.1 doesn`t help.
So... i installed PHP7.0 and migrate owncloud 10 to nextcloud 12, then 13->14->15.. then i have to upgrade php to 7.2 (nextcloud 16 is not supported by php7.0). After PHP upgrade i`ve installed nextcloud 16... Now Collabora online works!!
Hope this may help someone.
Best Regards.
Aug 06, 2019Guru - Experienced User
pl_shibby wrote:
I think something has been changed in kernel between 6.9.2 and 6.9.3...
The release notes say there was a security update to the kernel that might be getting in your way.
Is Collabora up to date?
FWIW, 6.10.x upgraded apache2, so there are more changes as you upgrade to current firmware.
pl_shibby
Yes, Collabora is up-to-date (6.0.10.29-292) but on older version was the same.
So why after upgrade to 6.9.3 Collabora stopped working and after back to 6.9.2 back to life? Here is the problem.
This is a big problem for me. I cannot use latest OS6 firmware because Collabora doesn`t work. BUT i have to upgrade firmware because the latest ownCloud doesn`t support PHP5.6... The best way is install PHP7.3 for future owncloud releases but for that i need apache2.4.
Best Regards
