pl_shibby
Aug 06, 2019Aspirant
Collabora Online stopped working after upgrade firmware to 6.9.3 and newer
I`m currently using firmware 6.9.2 on my Readynas Pro4. Everything works fine. I`m using Owncloud 10 with Collabora Online 6.0. But after upgrade ReadyNAS firmware to newer version (6.9.3, 6.9.5, al...
- Aug 11, 2019
FYI update to OS 6.10.1 doesn`t help.
So... i installed PHP7.0 and migrate owncloud 10 to nextcloud 12, then 13->14->15.. then i have to upgrade php to 7.2 (nextcloud 16 is not supported by php7.0). After PHP upgrade i`ve installed nextcloud 16... Now Collabora online works!!
Hope this may help someone.
Best Regards.
pl_shibby
Yes, Collabora is up-to-date (6.0.10.29-292) but on older version was the same.
So why after upgrade to 6.9.3 Collabora stopped working and after back to 6.9.2 back to life? Here is the problem.
This is a big problem for me. I cannot use latest OS6 firmware because Collabora doesn`t work. BUT i have to upgrade firmware because the latest ownCloud doesn`t support PHP5.6... The best way is install PHP7.3 for future owncloud releases but for that i need apache2.4.
Best Regards
pl_shibby
i don`t know why but each time i put some code in "code tag" (logs for example) my post has been deleted.
In attachment is a screen with an error from loolwsd service. On 6.9.2 this error doesn`t appear
- StephenBAug 06, 2019Guru - Experienced User
There's an automatic spam filter that is triggering for some reason. Mods will generally check the quarantine and eventually release false positives - but not always, since the real spam can be overwhelming. If you PM me or one of the mods we can release it for you.
pl_shibby wrote:In attachment is a screen with an error from loolwsd service. On 6.9.2 this error doesn`t appear
It's not something I use, so I can't help with debugging the application.
I am seeing several hits when I google for "loadcomponentfromURL returned an empty reference" that might give you some clues. They are mostly with older versions of Collabora.
- pl_shibbyAug 06, 2019Aspirant
i`m trying to fix it from an year. I readed a lot of threads, tried to implement any solution i found. Posting here is my act of desperate :(
I guess you could try moving forward to 6.10.1 (which would upgrade apache). It's conceivable that would behave differently.
The main problem there is that you can't downgrade back to 6.9.x. But if you are really stuck, that might not matter much.
