pl_shibby
Aug 06, 2019Aspirant
Collabora Online stopped working after upgrade firmware to 6.9.3 and newer
I`m currently using firmware 6.9.2 on my Readynas Pro4. Everything works fine. I`m using Owncloud 10 with Collabora Online 6.0. But after upgrade ReadyNAS firmware to newer version (6.9.3, 6.9.5, al...
- Aug 11, 2019
FYI update to OS 6.10.1 doesn`t help.
So... i installed PHP7.0 and migrate owncloud 10 to nextcloud 12, then 13->14->15.. then i have to upgrade php to 7.2 (nextcloud 16 is not supported by php7.0). After PHP upgrade i`ve installed nextcloud 16... Now Collabora online works!!
Hope this may help someone.
Best Regards.
pl_shibby
i am able to back from 6.10.x to 6.9.x ;) Already did it once. This is not a problem for me.
For week or two i should have readynas 102 "for fun". I will try install fresh 6.10.1, latest owncloud and collabora and we will see whats happened. Will let you know.
i will try also compare sources 6.9.2 and 6.9.3 and see what has been changed in kernel. Once i compiled kernel for readynas - needed module for mellanox 10GbE card ;) Should not a problem to compile whole kernel.
pl_shibby
Aug 11, 2019Aspirant
Best Regards.
