eb98jdb
Nov 30, 2014Aspirant
Configuring volumes
Hi, I've just added a new drive to my ReadyNas 102 - it has automatically configured itself as RAID and made a copy of the existing drive. I actually just want to address them as two separate volu...
mdgm-ntgr
Nov 30, 2014NETGEAR Employee Retired
Backup your data
Disable X-RAID
Delete the volume
Create the new volumes you want
Restore your data from backup.
Using separate volumes is not recommended. Why do you want to do this?
Disable X-RAID
Delete the volume
