babaraccas
Nov 20, 2011Aspirant
Considering RAM upgrade in Duo
I've got a ReadyNAS Duo v1 with the stock 256MB of RAM. I'm considering installing 1GB of RAM, not to increase read/write speeds, but to run add-ons more smoothly. I have transmission, and Twonky Medi...
mdgm-ntgr
Nov 20, 2011NETGEAR Employee Retired
I would suggest only trying modules recently suggested for the Duo v1 or NV+ v1. Some newer versions of modules retain the same module number but are no longer compatible.
