wiland
Oct 05, 2016Aspirant
Copying from RN516 to ReadyNas Pro 6
I have an older ReadyNas Pro 6 (w/ OS 4.2.27) and just purchased an RN516 (w/ OS 6). There is a Netgear article (Article ID 29730) that describes how to copy data from a RAIDiator 4 system to a Ready...
c3po
Oct 06, 2016NETGEAR Expert
Of course you can use Windows PC to do drag and drop copy from one NAS to the other. Drawbacks with drag and drop copy:
1. Your PC needs to do entire copy. It is best if your PC has fast connection to both NAS. It can take long time if you have a lot data on NAS
2. File access permissions might not what you want after Windows copies these files.
Oct 06, 2016Guru - Experienced User
Using a NAS backup job isn't that difficult, and will almost certainly be faster then drag and drop. Using the windows pc doubles the network traffic (everything goes to the PC and then back out to the other NAS).
