aalexandrebeta
Mar 04, 2017Master
CPU max temperature shutdown protection
Guys, I am A/C deprived in summer and wished to protect my device. I wish to know if it is posssible to lower the max temp threshold of the CPU or system? Regards.
mdgm-ntgr
Mar 04, 2017NETGEAR Employee Retired
If you really want to you could override the sensors config I think, but we set appropriate thresholds for each system.
You may wish to set the fan to cool mode. This will more aggressively spin up the fans to keep the system cool.
- aalexandrebetaMar 04, 2017Master
"You may wish to set the fan to cool mode. This will more aggressively spin up the fans to keep the system cool."
I am allready doing the "choper mode" in summer.
"If you really want to you could override the sensors config I think, but we set appropriate thresholds for each system."
I'll set pros and cons and get back to you if needed.
Thanks!
