CarlEdman
Aug 22, 2017Luminary
CrashPlan Alternatives
I've been using CrashPlan since 2014 to back up my ReadyNAS (about 9 TBytes used out of 20 TByte capacity). It's been great. Unlimited, continuous, encrypted, versioning backups running on the Read...
- Aug 24, 2017
Thanks to all those who replied.
Sadly, from these responses and my other inquiries, it seems that CrashPlan, even at twice the old price, is still the only viable solution for my case. Everything else either--and there are lots of other options--doesn't run under Linux or has a monthly cost for my use case that is an order of magnitude or more higher than even CrashPlan Pro.
The closest, widely-discussed alternative is BackBlaze. Unfortunately, their personal plan which is unlimited, inexpensive, and seems generally good, does not run under Linux. They do have a well-regarded B2 Cloud Storage plan which has multiple clients which might run om ReadyNAS, but it has a metered cost that would be much more expensive than CrashPlan Pro. The implication of discussions by the Backblaze CEO is that they have no plans to change either.
So when my CrashPlan Home plan expires at the end of the year, I plan to transition to CrashPlan Pro/SMB.
But if somebody comes up with something better (ideally before then!), please do respond here.
seanws78
Sep 11, 2017Tutor
I finally opted for using RCLONE with B2. I get RCLONE to encrypt my data before sending it as the B2 cloud is not encrypted.
Only issues I came into are:
Readynas Duo V2 has limited RAM so needed to increase my Swap file to accomodate. All working well now.
Transactions - B2 transactions are higher on new version of Rclone to make it perform quicker. I am running at 1350 transactions a day for a 160Gb backup (you get more than this free per day)
Bye Bye Crashplan
oshae
Sep 11, 2017Tutor
I briefly looked into RClone, no issues installing it?
Can you set up schedule style backups like typical backup tools?
- seanws78Sep 11, 2017TutorNo issues with the install. I have setup a Cron to run the sync process every evening. It checks the local files with the cloud and deletes or uploads as appropriate. B2 supports versions too so it keeps the deleted files as per your settings.
- smurff1975Sep 12, 2017Aspirant
Thanks for this. But why B2? I don't like the idea of getting charged dynamically. What I liked about CP was that is was unlimited. I have 3T of data but it doesn't grow consistantly.
- seanws78Sep 12, 2017TutorAt half a cent per GB per month plus 10gb free it made sense for me. I only have 160gb to backup. It costs me 75cents a month. Can't beat that anywhere.
