sdouek
Jul 07, 2015Guide
CrashPlan Cheat Sheet and Tweaks
lBelow are Command Codes, Tweaks and info on CrashPlan. If you need me to add any more or if something changes feel free to let me know and I will adjust it. #As of CrashPlan 4.2, CrashPlan wil...
scootle
Jul 17, 2015Aspirant
Great cheat sheet. Thanks.
Perhaps someone more experienced than I can help me troubleshoot this though... Crashplan v3.6.4 was working fine on my ReadyNAS Ultra4+ until recently... I'm not sure if something changed such that we require the latest versions of the clients to work with the CrashPlan service. So, updating to 4.3.0 seemed to work fine after uninstalling 3.6.4, but upon trying to launch 4.3.0 on my ReadyNAS the following is in the engine_error.log:
Any guidance on what to do about that?
I verified that "jre-7u45-linux-x64.tgz" properly downloaded and unpacked in the java path set on "JAVACOMMON=/usr/local/crashplan/jre/bin/java"
I am at a loss right now. Thanks.
/usr/local/crashplan/jre/bin/java: error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory
kahunamike
Aug 14, 2015Aspirant
Did you ever solve the jre issue? I'm getting the same error message after upgrading to 4.3.0
- scootleSep 16, 2015Aspirant
Nope, haven't yet solved this issue. My post was made right before the ReadyNAS.com forums were migrated, so everything was locked during the transition, so I presume nobody was able to read or reply to my inquiry.
For the time being, I am without a means to run CrashPlan.
Any suggestions are welcome. Thanks.
- StephenBSep 17, 2015Guru - Experienced User
4.3.0 is working on my pro-6.
install.vars has JAVACOMMON set to /usr/bin/java and /usr/bin/java is a link to /etc/alternatives/java. That is not a folder, it is a file. libdl.so.2 is in /lib.
Its been over three years since the initial install, and the details are a bit hazy :smileywink: But if there is more info I can gather, let me know.
I'd also recommend using crashplan support. Though they don't officially support headless, they did take my support case a few months ago.
- RedBulletOct 04, 2015Tutor
I did notice recently that my crashplan was filling up my rootfs. Basically the upgrade folder was filling up. ANyone know what that is all about?
Might want to include in your instructions how to relocate to /apps or something
