sdouek
Jul 07, 2015Guide
CrashPlan Cheat Sheet and Tweaks
lBelow are Command Codes, Tweaks and info on CrashPlan. If you need me to add any more or if something changes feel free to let me know and I will adjust it. #As of CrashPlan 4.2, CrashPlan wil...
kahunamike
Aug 14, 2015Aspirant
Did you ever solve the jre issue? I'm getting the same error message after upgrading to 4.3.0
/usr/local/crashplan/jre/bin/java: error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory
scootle
Sep 16, 2015Aspirant
Nope, haven't yet solved this issue. My post was made right before the ReadyNAS.com forums were migrated, so everything was locked during the transition, so I presume nobody was able to read or reply to my inquiry.
For the time being, I am without a means to run CrashPlan.
Any suggestions are welcome. Thanks.
