sdouek
Jul 07, 2015Guide
CrashPlan Cheat Sheet and Tweaks
lBelow are Command Codes, Tweaks and info on CrashPlan. If you need me to add any more or if something changes feel free to let me know and I will adjust it. #As of CrashPlan 4.2, CrashPlan wil...
scootle
Jul 17, 2015Aspirant
Great cheat sheet. Thanks.
Perhaps someone more experienced than I can help me troubleshoot this though... Crashplan v3.6.4 was working fine on my ReadyNAS Ultra4+ until recently... I'm not sure if something changed such that we require the latest versions of the clients to work with the CrashPlan service. So, updating to 4.3.0 seemed to work fine after uninstalling 3.6.4, but upon trying to launch 4.3.0 on my ReadyNAS the following is in the engine_error.log:
Any guidance on what to do about that?
I verified that "jre-7u45-linux-x64.tgz" properly downloaded and unpacked in the java path set on "JAVACOMMON=/usr/local/crashplan/jre/bin/java"
I am at a loss right now. Thanks.
/usr/local/crashplan/jre/bin/java: error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory
chriscena
Oct 05, 2015Aspirant
I managed to get Crashplan 4.4.1 up and running on my NAS (ReadyNAS Ultra 4). All I had to do was to swap out the x64 JRE package with the 586 version instead, after completing the usual install. The install.defaults file contains the URL for the correct file, so just download that one:
(I'm doing all of this in ~/crashplan-install/)
wget http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz
then unpack and swap the x64 version with the 586 version:
tar -zxf jre-7-linux-i586.tgz
mv /usr/local/crashplan/jre/ /usr/local/crashplan/jre-x64
mv ~/crashplan-install/jre /usr/local/crashplan/jre
then start the Crashplan service. Voila!
Obviously, the installer picks the wrong architecture for the NAS. Hope this helps.
- scootleOct 05, 2015Aspirant
Yeah, that appears to be the issue... the Crashplan installer script does not pick the correct architecture for the ReadyNAS Ultra4+ it seems. I guess we should report that to them, but that said, we are shoe-horning the vanilla "Linux" install onto a NAS, which they show as unsupported.
Thanks all. Hope this helps others in the same boat.
- StephenBOct 05, 2015Guru - Experienced User
That wasn't really my problem. The upgrade failed right away because the java version was 1.6. Crashplan did not attempt to update java.
Wed Sep 23 20:39:17 EDT 2015 : JAVACOMMON is set: /usr/bin/java
Wed Sep 23 20:39:17 EDT 2015 : Current Java Version: 1.6
Wed Sep 23 20:39:17 EDT 2015 : This client requires one of these JREs: 1.7 1.8. Exiting upgradeInstalling jre 1.8 (and changing JAVACOMMON to point to it) solved the problem.
StephenB wrote:
chriscena wrote:Obviously, the installer picks the wrong architecture for the NAS. Hope this helps.
How did you go about installing JRE 1.8 directly on your ReadyNAS? I tried to find an apt-get repository that worked, but that failed. I only have a working version of JRE 1.6 (when Java was still Sun) that was installed directly via apt-get (Debian archive).
The EJRE installer add-on for the ReadyNAS failed to even install for me.
The add-on installer worked for me with no issues
