sdouek
Jul 07, 2015Guide
CrashPlan Cheat Sheet and Tweaks
lBelow are Command Codes, Tweaks and info on CrashPlan. If you need me to add any more or if something changes feel free to let me know and I will adjust it. #As of CrashPlan 4.2, CrashPlan wil...
chriscena
Oct 05, 2015Aspirant
I managed to get Crashplan 4.4.1 up and running on my NAS (ReadyNAS Ultra 4). All I had to do was to swap out the x64 JRE package with the 586 version instead, after completing the usual install. The install.defaults file contains the URL for the correct file, so just download that one:
(I'm doing all of this in ~/crashplan-install/)
wget http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz
then unpack and swap the x64 version with the 586 version:
tar -zxf jre-7-linux-i586.tgz
mv /usr/local/crashplan/jre/ /usr/local/crashplan/jre-x64
mv ~/crashplan-install/jre /usr/local/crashplan/jre
then start the Crashplan service. Voila!
Obviously, the installer picks the wrong architecture for the NAS. Hope this helps.
scootle
Yeah, that appears to be the issue... the Crashplan installer script does not pick the correct architecture for the ReadyNAS Ultra4+ it seems. I guess we should report that to them, but that said, we are shoe-horning the vanilla "Linux" install onto a NAS, which they show as unsupported.
Thanks all. Hope this helps others in the same boat.
