tony359
Aug 09, 2018Apprentice
Crashplan for small business on headless
Hello all,
This is a continuation of the following thread which was closed for inactivity
https://community.netgear.com/t5/Using-your-ReadyNAS/TIP-CrashPlan-Pro-4-9-DOES-Work-With-Headles...
tony359
Hi Carl,
Very much appreciated, thanks.
On what NAS did you install Crashplan and what OS are you running? I am still on OS4 and I cannot install Xorg - I have a feeling that the software is set to check on the ReadyNas website and Xorg is not available on that OS? But my Linux is just basic.
CarlEdman
Aug 09, 2018Luminary
AH, that could be a problem! I am running OS 6.9.3, but on ancient hardware: A ReadyNAS Ultra 6 Plus that I bought almost 8 years ago. Never regretted the upgrade to OS 6, but storing all your data off the system while you reformat to OS 6 can be a pain.
FWIW, my /etc/apt/sources.list is:
deb http://apt.readynas.com/packages/readynasos 6.9.3 updates apps main deb http://mirrors.kernel.org/debian jessie main deb http://security.debian.org/ jessie/updates main
- tony359Aug 09, 2018Apprentice
Thank you! I didn't even know how to change the sources.
I guess it's time to update but as you say it's difficult to park the several TB's of data while I wipe and reinstall! Maybe I'll find a way.
I'll keep you posted, thanks for your help in the meantime!
- CarlEdmanAug 10, 2018Luminary
My pleasure. If you (or anyone else coming across this thread) could use help at a level below key-for-key instructions, I'm happy to offer it!
- SSteenvoordenAug 25, 2018Initiate
Thanks CarlEdman for your feedback! With some struggles I was able to got it working on my ReadyNas Ultra 6 with firmware 6.9.3.
In order to help the others I will add the steps that I had to perform in addition to the steps that CarlEdman supplied:
1) Removed line "DISPLAY=localhost:10.0" in ~/.bashrc. For some reason localhost was not resolving. Therefore I performed step 2. 2) ran echo "DISPLAY=127.0.0.1:10.0" >> ~/.bashrc 3) ran apt-get install libgtk-3-0 4) ran apt-get install libxss1 5) ran apt-get install libgconf-2-4
After these actions no errors where reported anymore in ~/.code42/logs/ui_error.log.
I hope this helps anyone else in getting it working.
