dlevens
May 18, 2016Aspirant
Crashplan no longer autostarts on 6.5.0
I updated my ReadyNas 516 from 6.4.2 to 6.5.0 and now crashplan no longer starts on bootup. I have tried uninstalling and reinstalling crashplan 4.7.0 but it will not auto start on boot up. I ca...
- May 20, 2016
Thanks to Viktor over at the Code42 forums, I have a working solution. The problem was I was missing a few symbolic links in the run folders. In my case, even after a fresh install of crashplan 4.7.0 I only had a single symbolic link in "/etc/rc5.d/S02crashplan" that pointed to my init script for the CrashPlanEngine service: “/etc/init.d/crashplan"
For those with my same issue, I only had to do these commands to solve this:
ln -s /etc/init.d/crashplan /etc/rc0.d/K01crashplan
ln -s /etc/init.d/crashplan /etc/rc1.d/K01crashplan
ln -s /etc/init.d/crashplan /etc/rc2.d/S01crashplan
ln -s /etc/init.d/crashplan /etc/rc3.d/S01crashplan
ln -s /etc/init.d/crashplan /etc/rc4.d/S01crashplan
ln -s /etc/init.d/crashplan /etc/rc6.d/K01crashplanupdate-rc.d crashplan defaults
kohdee
May 19, 2016Administrator
CrashPlan being installed on the OS volume is not recommended. But anyway, what script were you using to start it automatically in the first place?
May 20, 2016Guru - Experienced User
Perhaps, though it is generally safe enough if you reconfigure the cache location (and perhaps symlink the upgrade folder).
If the OP was using the normal crashplan install, Crashplan would have created a symlink ( /etc/init.d/crashplan ) to /usr/local/crashplan/bin/CrashplanEngine
