iearmand
Jan 09, 2012Aspirant
Crashplan on Duo/NV+ v2? [SOLVED + TUTORIAL]
UPDATED: See filzip77's post below for a guide\Tutorial on how to install I’m new to the forums so please be gentle …. I’m looking to venture into having a dedicated/off the shelf NAS rather the...
sphardy1
Apr 08, 2012Apprentice
Progress:
Unfortunately, while I can get the Crashplan engine running, I cannot then use the NAS as a backup target - I constantly get the message "backup disabled - not available" as if the backup location is not available (not true)
Only error report is the following related to iNotify:
Quite a few reports of this that I've tried various solutions to (eg modify java tmp dir) but with no success.
Have now run out of time on this so if anyone has any thoughts, let me know
Exception in thread "W11700608_ScanWrkr" java.lang.NoClassDefFoundError: Could not initialize class com.code42.jna.inotify.InotifyManager
at com.code42.jna.inotify.JNAInotifyFileWatcherDriver.<init>(JNAInotifyFileWatcherDriver.java:21)
at com.code42.backup.path.BackupSetsManager.initFileWatcherDriver(BackupSetsManager.java:392)
at com.code42.backup.path.BackupSetsManager.startScheduledFileQueue(BackupSetsManager.java:330)
at com.code42.backup.path.BackupSetsManager.access$1600(BackupSetsManager.java:65)
at com.code42.backup.path.BackupSetsManager$ScanWorker.delay(BackupSetsManager.java:1035)
at com.code42.utils.AWorker.run(AWorker.java:158)
at java.lang.Thread.run(Thread.java:636)
