iearmand
Jan 09, 2012Aspirant
Crashplan on Duo/NV+ v2? [SOLVED + TUTORIAL]
UPDATED: See filzip77's post below for a guide\Tutorial on how to install I’m new to the forums so please be gentle …. I’m looking to venture into having a dedicated/off the shelf NAS rather the...
sphardy1
Apr 11, 2012Apprentice
1. The Service file is called "my.service.xml" - also the code you quoted is not correct and does not match the instructions
2. You appear to be running the wrong java installation - you shouldn't be running any java included with the Crashplan installation. Check your path and java environment settings
