iearmand
Jan 09, 2012Aspirant
Crashplan on Duo/NV+ v2? [SOLVED + TUTORIAL]
UPDATED: See filzip77's post below for a guide\Tutorial on how to install I’m new to the forums so please be gentle …. I’m looking to venture into having a dedicated/off the shelf NAS rather the...
iearmand
Apr 12, 2012Aspirant
Thanks filzip77. That fixed the issue and Crashplan is now syncing.
Thanks for all the help guys...I had already conceded that I would never have Crashplan working on my NV+v2, to now having it working is just great.
filzip77 as I was working though your install instructions I made a few mistakes and had to go looking else where for things I did not full understand. They may seem obvious to you guys but they took bit of digging for me....if you update your thread they might help others.
During installation I was confused about what options to set when install crashplan. To keep consistent I used your dir structure:
Location of Service file would help:
again thanks a million for you work in getting Crashplan working...
Your selections:
CrashPlan will install to: /c/home/Philippe/crashplan
And put links to binaries in: /usr/local/bin
And store datas in: /c/home/Philippe/crashplan/manifest
Your init.d dir is: /etc/init.d
Your current runlevel directory is: /etc/rc2.d
Is this correct? (y/n) [y] y
/c/home/Philippe/crashplan/conf/my.service.xml
