iearmand
Jan 09, 2012Aspirant
Crashplan on Duo/NV+ v2? [SOLVED + TUTORIAL]
UPDATED: See filzip77's post below for a guide\Tutorial on how to install I’m new to the forums so please be gentle …. I’m looking to venture into having a dedicated/off the shelf NAS rather the...
Apr 13, 2012Guru - Experienced User
Are you CPU bound?
iearmand wrote: Was wondering if you guys were seeing any speed issues?
Normally I get 1.2Meg up but at the moment it does not seem to go over 300k up....have tried a few setting on the Crashplan client but to no avail...
Not sure what you tried, but the normal adjustments are
advanced backup settings
- data deduplication=minimal
compression=off
network settings
- sending message buffer size=2560
I've also found that performance varies by file type.
BTW, if you want to restart the service after you apply changes, try clicking on the house icon on the upper right of the client. It will open a command box, with a reference list of supported commands. Restart is one of them. Stopping the service (which is also there) is not so useful, since the client can't restart it.
