iearmand
Jan 09, 2012Aspirant
Crashplan on Duo/NV+ v2? [SOLVED + TUTORIAL]
UPDATED: See filzip77's post below for a guide\Tutorial on how to install I’m new to the forums so please be gentle …. I’m looking to venture into having a dedicated/off the shelf NAS rather the...
filzip77
Apr 13, 2012Aspirant
I kept all default values.
The default upload transfer increased and stabilized around 1.3 Mbps (most of the files are pictures of 5MB).
I decided to limit the upload to 800 Kbps in order to do not slow down too much my internet connection.
Have you check your CPU load? The command is
What are the size of the files you transfer? Remember that the NAS ARM has a CPU much less powerful than in your PC. Computing the hash table (MD5) for a big file may use a lot of CPU time on the ReadyNas ARM.
On my side I did not notice a high CPU load during the transfer.
top
