iearmand
Jan 09, 2012Aspirant
Crashplan on Duo/NV+ v2? [SOLVED + TUTORIAL]
UPDATED: See filzip77's post below for a guide\Tutorial on how to install I’m new to the forums so please be gentle …. I’m looking to venture into having a dedicated/off the shelf NAS rather the...
Apr 13, 2012Guru - Experienced User
This depends on the file size and the file extension. Photos are probably small enough that CPU load is not a factor. DVD or BluRay media files are another matter. Though at 1 mbps it might not be practical to back those up to CrashPlan Central anyway.
filzip77 wrote: On my side I did not notice a high CPU load during the transfer.
The 3.2 engine seems to be better on CPU than the older 3.0 engine though. My pro is uploading at about 8 mbps at the moment, and the CPU load is only 3%. I think it was much higher in early March (with the old engine). Back then I was frequently saturating one of the Pro cores. It is still taking about half the memory though.
