iearmand
Jan 09, 2012Aspirant
Crashplan on Duo/NV+ v2? [SOLVED + TUTORIAL]
UPDATED: See filzip77's post below for a guide\Tutorial on how to install I’m new to the forums so please be gentle …. I’m looking to venture into having a dedicated/off the shelf NAS rather the...
iearmand
Apr 13, 2012Aspirant
I may have been following a red heron. I was checking through my my.service.xml file looking to change some settings and noticed that my servicehost setting had not been set correctly (0.0.0.0). when I fixed it crashplan started to sync correctly older files rather then upload them.
once the initial sync is done I will take a closer look at the upload speeds I get.
one thing I have noticed is that crashplan does start to slow on PC when you have a vast amount of small files....I'm guessing ths part MD5, part file reading, part de-dup & part compression. I will tale a closer look once the intial sync is complete.
Thanks for the feedback though. will give me plenty to fiddle with.
