iearmand
Jan 09, 2012Aspirant
Crashplan on Duo/NV+ v2? [SOLVED + TUTORIAL]
UPDATED: See filzip77's post below for a guide\Tutorial on how to install I’m new to the forums so please be gentle …. I’m looking to venture into having a dedicated/off the shelf NAS rather the...
mpdeglau
Dec 06, 2012Aspirant
I'm getting this error when I try to install libjna-java
I've tried using -f to correct it, but it doesn't work. Does anyone know what I need to do?
Thanks
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
libc6-dev : Depends: libc6 (= 2.11.3-4) but 2.11.2-10 is to be installed
libjna-java : Depends: libffi5 (>= 3.0.9-2) but it is not going to be installed
tzdata-java : Depends: tzdata (= 2012g-0squeeze1) but 2012c-0squeeze1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Thanks
