iearmand
Jan 09, 2012Aspirant
Crashplan on Duo/NV+ v2? [SOLVED + TUTORIAL]
UPDATED: See filzip77's post below for a guide\Tutorial on how to install I’m new to the forums so please be gentle …. I’m looking to venture into having a dedicated/off the shelf NAS rather the...
mpdeglau
Dec 08, 2012Aspirant
I finally got it to work.
If anyone ever comes across this, this is what I did. I ended up breaking the apache server somehow doing some random debian updates and installs.
Reinstalled the OS on the NAS and uninstalled crashplan.
Followed the directions on the first page from the beginning.
Once I was installing libjna-java I got the error:
I then tried
This error came up:
This was fixed by
I was then able to install libjna-java. From there everything worked as expected and I'm in the process of backing my server up to CrashPlan
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
cifs-utils : Depends: libtalloc2 (>= 2.0.0) but it is not going to be installed
libjna-java : Depends: libffi5 (>= 3.0.9-2) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I then tried
apt-get -f install libtalloc2
This error came up:
dpkg: error processing /var/cache/apt/archives/libtalloc2_2.0.1-1_armel.deb (--unpack):
trying to overwrite '/usr/lib/libtalloc.so.2', which is also in package samba 2:3.5.15-njnetgear1
configured to not write apport reports
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
This was fixed by
dpkg -i --force-overwrite /var/cache/apt/archives/libtalloc2_2.0.1-1_armel.deb
