iearmand
Jan 09, 2012Aspirant
Crashplan on Duo/NV+ v2? [SOLVED + TUTORIAL]
UPDATED: See filzip77's post below for a guide\Tutorial on how to install I’m new to the forums so please be gentle …. I’m looking to venture into having a dedicated/off the shelf NAS rather the...
Dec 16, 2012Guru - Experienced User
That seems odd. I suppose you could try uninstalling-reinstalling CP on that PC.
You could also try submitting the issue to crashplan (or post it in their forums), though if you are only using the free version they might not give you too much help.
