iearmand
Jan 09, 2012Aspirant
Crashplan on Duo/NV+ v2? [SOLVED + TUTORIAL]
UPDATED: See filzip77's post below for a guide\Tutorial on how to install I’m new to the forums so please be gentle …. I’m looking to venture into having a dedicated/off the shelf NAS rather the...
cmcloughlin
Dec 30, 2012Aspirant
Thanks Stephen - I had already done that but I think I have found the problem - again on the router!!. This is a new NAS which replaced an old Duo and was set to the same static address. What I had forgotten to do was to set the MAC address in the router's IP address Binding. Strangely almost everything worked, I was able to access the NAS but it seemed to mess up connections from the NAS while allowing internals ones to work. Anyhow now backing up from outside the office.
Thanks for all your help getting this sorted.
