tony359
Mar 24, 2016Apprentice
Crashplan unable to connect
Hello there, I've moved house and ISP provider. Crashplan now fails to connecto to CrashPlan central. I can ping the internet from the NAS, the service seems up and no specific errors logged that...
tony359
Mar 25, 2016Apprentice
Yes it has. I've updated my pc as well but no change.
I'll ask code42 thanks.
Probably unrelated but... When I powered the NAS back in the new home it went into boot mode, I rebooted and went into boot mode again. I couldn't even navigate through the menus - unless I was just doing it wrong. Rebooted again and it was fine.
Now all is fine BUT if I SSH into the unit it takes about 20s before it asks for the password. If I sFTP into it, it times out most of the time. When it eventually connect, it then works but when I transfer some files, it takes ages to begin, most of the time it times out.
Could this be somehow related?
Mar 25, 2016Guru - Experienced User
Possibly. Have you checked for a full OS partition?
Also, it might be good to check the disk health - perhaps something got bumped during transport.
- tony359Mar 25, 2016Apprentice
Disk health is fine. No errors reported by NAS. I can access my shares with no delay and no issues.
If I'm not mistaken the OS partition is not full, see below
Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 1.9G 1.9G 51% / tmpfs 16K 0 16K 0% /USB /dev/c/c 3.7T 1.4T 2.3T 37% /c /c/guests 3.7T 1.4T 2.3T 37% /home/ftp/guests
