sleeplesswaves
Mar 10, 2023Aspirant
Creating an instance of Raidiator 6.10.8 as a virtual machine?
Is there a way to create an instance of Raidiator 6.10.8 as a VM? I want to be able to use Parallels on my mac with an install of of 6.10.8 so I can test software installs without risk. I tried just ...
- Mar 10, 2023
https://github.com/ReadyNAS/sdk/wiki/Setup-ReadyNAS-OS-on-VirtualBox
Once you get it running, you can update to OS 6.10.8 just as you would a real NAS.
Sandshark
Mar 10, 2023Sensei
- sleeplesswavesMar 10, 2023Aspirant
Excellent, thank you!
- sleeplesswavesMar 11, 2023Aspirant
I wasn't able to get this working via Virtual Box, VMware or Parallels.
On VMware I loaded the .vmdk and start it, but get:>>Start PXE over IPv4.
PXE-E16: No valid offer received.
>>Start PXE over PVv6
Then it produces the attachment.
Looks like it's trying to network boot?
The Virtual Box gives this error:
28.2241331 MMI Watchdog: BUG: soft lockup - CPU#0 stuck for 23s! swapper/0Any ideas?
- SandsharkMar 11, 2023Sensei
t sounds like you failed to attach the boot drive, which emulates the internal flash of a real ReadyNAS, to the VM per the instructions in that article.
I've tried this multiple times now. I think I'm following the directions exactly but it still fails with the same error. I have created two SATA ports:
SATA Port 0: ReadyNASOS-6.6.0-x86_64.vmdk (Normal, 112MB)SATA Port 1: ReadyNAS OS VM_1.vhd (Normal, 5GB)
I've also tried creating two .vhd's 5GB each
I've also tried creating a VDI instead of a VHD because in the example pictures the extension for the data drive is .vdi
The instructions mention the minimum disk size should be 5GB, and the .vmdk is only 112MB, perhaps it's too small? I couldn't figure out how to expand that disk to 5GB to test though.
You are using a UEFI boot. It needs to be standard BIOS.
Here is my configuration:
Can't seem to edit my reply, but I wanted to add that the boot drive emulates the flash memory in a real NAS, so it's smaller. Since the OS partition is 4GB, and swap is 512K, you are really going to want a bigger data drive than 5GB.
