sleeplesswaves
Mar 10, 2023Aspirant
Creating an instance of Raidiator 6.10.8 as a virtual machine?
Is there a way to create an instance of Raidiator 6.10.8 as a VM? I want to be able to use Parallels on my mac with an install of of 6.10.8 so I can test software installs without risk. I tried just ...
- Mar 10, 2023
https://github.com/ReadyNAS/sdk/wiki/Setup-ReadyNAS-OS-on-VirtualBox
Once you get it running, you can update to OS 6.10.8 just as you would a real NAS.
sleeplesswaves
Mar 12, 2023Aspirant
Okay, finally.... I tried setting this up on my Windows 11 AMD machine... It worked (after I enabled virtualization in the BIOS)...
Now I'm stuck at a login screen... I've tried:
login: admin
password: password
login: admin
password: netgear1
Neither worked. Any ideas?
I think my problems running this on the Mac M1 was using a beta version of the ARM Virtualbox... Something isn't ready for prime time.
Mar 12, 2023Guru - Experienced User
login: admin
password: password
login: adminpassword: netgear1
Default admin password for OS-6 is password.
Is the system booting from the OS partition (which is on the RAID disks, not the flash)?
