Bains
Nov 11, 2015Guide
CryptoLocker and a backup strategy
I am requesting the community to evaluate and criticize this approach to CyberLocker We are basically a Windows shop and we are scared to death about the CyperLocker virus. From what I read, ...
- Nov 13, 2015
Let's summarize this thread. I will open a new thread regarding the Netgear implementation/use of the rsync command.
CryptoLocker and its variants are ‘in the wild’ and using an infected PC to encrypt most files as well as the file and directory names. The malware chases all local drives and any mapped drives as it encrypts the data. Once encrypted users are told to pay a ransom of between $700 and $70,000 dollars in bitcoins or never recover their data.
Currently the only way to feasibly recover the data is either pay a ransom or restore the data from backup files. The backup files should be on a ReadyNAS share that does not have SMB access enabled so the malware cannot detect the data – it is not part of a mapped drive.
The intention is to have backup of various Windows files and directories on a ReadyNAS that are the object of drive mapping in local PC network.
- The backup share should be established without SMB protocol enabled. Turn SMB off in the Network Access tab in the file properties
- The rsync protocol should be enabled and Read/Write access should be allowed. Use the Network Access tab in the file properties.
Now there is a location for file backups that will not be discovered by CryptoLocker.
The next step is to establish a backup job(s) to copy the ‘live’ mapped data to the essentially hidden data area.
Nov 11, 2015Guru - Experienced User
CryptoLocker was shut down in the June 2014, and the encryption key was broken in August 2014 (https://en.wikipedia.org/wiki/CryptoLocker). Though of course malware generally is getting more and more sophisticated over time.
Since hidden files and folders can easily be seen in windows (just by choosing the right explorer option), it might not be a very effective countermeasure by itself. Though it does no harm, and could be helpful.
I think you can do better though - keeping the 7 daily shares completely inaccessible from windows (SMB turned off, at least most of the time).
I'm thinking that you back up the PCs to share X daily (say at 0100). Share X is hidden SMB. Then create 7 backup jobs (one for each day of the week) in frontview. Have them start after the daily PC backup normally finishes - say 1300. Each would use incremental rsync. On Monday, back up X to the Monday share; on Tuesday back up X to the Tuesday share, etc.
