daniel21's avatar
daniel21
Data Degraded - Webinterfacce offline - ssh active - need help
Hi community, I replaced my Disk in Bay 3 from 3TB drive with new 4TB drive.
After rebooting NAS message apperas "DATA DEGRADED".
The webinterface at https://readynas.local is not available.
Command Line via SSH is still active with root access.
All 4 Disk in Bays are in Front LED Panel "Blue" as active.
I am on ReadyNAS OS 6.9.0-T62 (Beta 2).
Please can anymone help me ?
I can post Logs if needed.
Thanks
    • daniel21's avatar
      daniel21
      Thanks a lot for your support:
      All 4 Disk are green and in good condition.
      Status: Management service is offline
      Successfully completed diagnostics System
      • Volume swap is 100.00% full
      • Volume data is 93.59% full
      Logs
      • 2017-09-18 17:17:21: md/raid:md127: raid level 5 active with 3 out of 4 devices, algorithm 2
      • 2017-09-17 22:26:57: ufsd: "umount" (sdd1): is unmounted at 2017-09-17 20:26:57
      • 2017-09-17 21:32:55: ufsd: "mount" (sdd1): is mounted as NTFS at 2017-09-17 19:32:55
      • 2017-09-17 21:21:17: ufsd: "umount" (sdd1): is unmounted at 2017-09-17 19:21:17
      • 2017-09-17 21:08:33: ufsd: "mount" (sdd1): is mounted as NTFS at 2017-09-17 19:08:33
      • 2017-09-17 20:54:20: md/raid:md127: raid level 5 active with 3 out of 4 devices, algorithm 2
      • 2017-09-17 20:39:48: ufsd: "umount" (sdb): is unmounted at 2017-09-17 18:39:48
      • 2017-09-17 16:04:55: ufsd: "mount" (sdb): is mounted as NTFS at 2017-09-17 14:04:55
      • 2017-09-17 15:59:49: md/raid:md127: raid level 5 active with 3 out of 4 devices, algorithm 2
      • 2017-09-17 15:42:05: md/raid:md126: raid level 5 active with 3 out of 4 devices, algorithm 2
      • 2017-09-17 15:42:04: md/raid:md127: raid level 5 active with 3 out of 4 devices, algorithm 2
      • 2017-09-17 10:56:27: md/raid:md126: raid level 5 active with 3 out of 4 devices, algorithm 2
      • 2017-09-17 10:56:26: md/raid:md127: raid level 5 active with 3 out of 4 devices, algorithm 2
      • 2017-09-17 10:06:36: md/raid:md126: raid level 5 active with 3 out of 4 devices, algorithm 2
      • 2017-09-17 10:06:35: md/raid:md127: raid level 5 active with 3 out of 4 devices, algorithm 2
      Greetings
      • StephenB's avatar
        Is the data available from Windows File Explorer (or finder)?
ProSupport for Business
