daniel21
Sep 17, 2017Aspirant
Data Degraded - Webinterfacce offline - ssh active - need help
Hi community, I replaced my Disk in Bay 3 from 3TB drive with new 4TB drive. After rebooting NAS message apperas "DATA DEGRADED". The webinterface at https://readynas.local is not available. Comm...
Sep 18, 2017Guru - Experienced User
What status does RAIDar show?
daniel21
Sep 18, 2017Aspirant
Thanks a lot for your support:
All 4 Disk are green and in good condition.
Status: Management service is offline
Successfully completed diagnostics System
- Volume swap is 100.00% full
- Volume data is 93.59% full
Logs
- 2017-09-18 17:17:21: md/raid:md127: raid level 5 active with 3 out of 4 devices, algorithm 2
- 2017-09-17 22:26:57: ufsd: "umount" (sdd1): is unmounted at 2017-09-17 20:26:57
- 2017-09-17 21:32:55: ufsd: "mount" (sdd1): is mounted as NTFS at 2017-09-17 19:32:55
- 2017-09-17 21:21:17: ufsd: "umount" (sdd1): is unmounted at 2017-09-17 19:21:17
- 2017-09-17 21:08:33: ufsd: "mount" (sdd1): is mounted as NTFS at 2017-09-17 19:08:33
- 2017-09-17 20:54:20: md/raid:md127: raid level 5 active with 3 out of 4 devices, algorithm 2
- 2017-09-17 20:39:48: ufsd: "umount" (sdb): is unmounted at 2017-09-17 18:39:48
- 2017-09-17 16:04:55: ufsd: "mount" (sdb): is mounted as NTFS at 2017-09-17 14:04:55
- 2017-09-17 15:59:49: md/raid:md127: raid level 5 active with 3 out of 4 devices, algorithm 2
- 2017-09-17 15:42:05: md/raid:md126: raid level 5 active with 3 out of 4 devices, algorithm 2
- 2017-09-17 15:42:04: md/raid:md127: raid level 5 active with 3 out of 4 devices, algorithm 2
- 2017-09-17 10:56:27: md/raid:md126: raid level 5 active with 3 out of 4 devices, algorithm 2
- 2017-09-17 10:56:26: md/raid:md127: raid level 5 active with 3 out of 4 devices, algorithm 2
- 2017-09-17 10:06:36: md/raid:md126: raid level 5 active with 3 out of 4 devices, algorithm 2
- 2017-09-17 10:06:35: md/raid:md127: raid level 5 active with 3 out of 4 devices, algorithm 2
Greetings
- StephenBSep 18, 2017Guru - Experienced User
Is the data available from Windows File Explorer (or finder)?
daniel21 wrote:
yes, Share + Files are available from mac os finder
Good. It would be prudent to back up what files you can (if you don't have a full backup).
Since you are running the beta firmware, it's best to wait a bit longer and see if Netgear offers to troubleshoot.
