Sharpy
Jan 22, 2017Aspirant
Data integrity rn104
I am using a rn104 for my main media server and run backups from the rn104 to external drives MY drives in the nas are WD REDS in JBOD mode What I was wondering is there any data integrity check...
Sharpy
Could you also explain a little more on how bit rot protection works
1 How do I schedule scans
2 How would I know if there is corruption
3 Does it scan the file when it's being accessed
4 Is there any point in enabling it as my setup is JBOD not RAID
And a couple of different questions
A) As my setup is not raid is there any point in using the volume tools scrub, balance, defrag, disk test
B) what is the best ethernet teaming policy I currently use round robbin
- StephenBJan 22, 2017Guru - Experienced User
Sharpy wrote:
3 Does it scan the file when it's being accessedIf checksums are enabled, they are verified whenever a data block is read from the disk. So you'll get an error whenever you (or a NAS system process) reads the file.
Sharpy wrote:
4 Is there any point in enabling it as my setup is JBOD not RAIDYou'd detect corruption if the checksums are enabled. But Netgear's bitrot repair depends on RAID.
Sharpy wrote:
A) As my setup is not raid is there any point in using the volume tools scrub, balance, defrag, disk testYes. Defrag and disk test have nothing to do with RAID. Balance can reclaim free space (even on jbod) so it also makes sense to run it on jbod. Scrub will verify the btrfs checksums.
Sharpy wrote:
B) what is the best ethernet teaming policy I currently use round robbinOn the RN104 the best policy is to leave teaming off. Your NAS is processor bound, and can't keep up with a single gigabit connection. So there's really no point to teaming.
More generally - If your switch or router supports LACP, then use that. Otherwise I'd normally suggest ALB and TLB (in that order). All the non-LACP modes can cause problems, so if you see connectivity or speed issues then you should revert back to non-bonding mode.
