hksscom
Feb 18, 2022Apprentice
ddclient for DynDns on RN300 - Working
It took me a while to get ddclient to work on my ReadyNAS RN300 series, but eventually, redstamp user provided the key hint I needed. Note: I will be publishing this same post with more details a...
hksscom
Hi, Sandshark!
Indeed, I could not get Poussin's DDclient 1.0 to work today until after a few hours of research and trial and error. This was with the ReadyNAS RN314 and OS6 6.10.6.
I've written a full article (with screenshots) detailing the steps here: Netgear ReadyNAS: DDclient Configuration for Dynamic DNS (DynDNS, No-IP) - YuenX.
Hope this helps others!
Sandshark
Feb 19, 2022Sensei
Oh, I remember now that I had to do this, then the configuration in the ddconf share works:
Create (or add to if it exists) /etc/frontview/samba/addons/addons.conf
With the following:
[global] allow insecure wide links = yes unix extensions = no [ddclient] follow symlinks = yes wide links = yes
Those used to be the defaults, but changed in an update to SMB some time back. I forget which OS version included that update.
Obviously, there's another way, which you have detailed. Since both need SSH, I don't think there's a preference as to which is used.
- hksscomFeb 22, 2022Apprentice
Thanks for sharing! Good to know that /data/ddclient/ddclient.conf could still work if making the extra changes you listed.
