MARKEYBOY
May 31, 2016Aspirant
Delete corrupt playlist subfolder on RN10400
Hi All. Something bugging me and want to sort it out. I have a ReadyNAS 104 and I want to delete a subfolder of the systems folder called "ReadyNAS_104\Music\Playlists". I can see it in Windows Ex...
- Aug 11, 2016
Success!! Thank you!
IN Windows File Explorer, selected "NAS_VALLEYSIDE" under "Network". Searched for word "Cypress" and it found them. From here the DELETE option is available.
I will now run a re-scan just to finish off. If totally good will mark as an Accepted Solution.
Thanks for your time.
BrianL2
May 31, 2016NETGEAR Employee Retired
Hi MARKEYBOY,
Does this sub-folder visible in the 'Share' tab in the admin page? Maybe resetting the permission of the 'ReadyNAS_104\Music\Playlists' will help you delete this sub-folder on your PC via Windows File Explorer.
Kind regards,
BrianL
NETGEAR Community Team
- MARKEYBOYAug 09, 2016Aspirant
Hi. There are no folders whatsoever visible on the Share called 'Music'. If there were, I'm sure I could achieve my goal.
So, any expert advice how to access 'ReadyNAS_104\Music\Playlists' through the Admin Page would be most appreciated. This is bugging me! :(
- BrianL2Aug 09, 2016NETGEAR Employee Retired
Hi MARKEYBOY,
If it's not seen in the admin page, I suspect that this is a a cache on your PC. Could you post a screenshot so we can confirm?
Kind regards,
BrianL
NETGEAR Community Team- MARKEYBOYAug 10, 2016Aspirant
Hi BrianL.
Post a screenshot of what exactly?
Regards
Mark
