MARKEYBOY
May 31, 2016Aspirant
Delete corrupt playlist subfolder on RN10400
Hi All. Something bugging me and want to sort it out. I have a ReadyNAS 104 and I want to delete a subfolder of the systems folder called "ReadyNAS_104\Music\Playlists". I can see it in Windows Ex...
- Aug 11, 2016
Success!! Thank you!
IN Windows File Explorer, selected "NAS_VALLEYSIDE" under "Network". Searched for word "Cypress" and it found them. From here the DELETE option is available.
I will now run a re-scan just to finish off. If totally good will mark as an Accepted Solution.
Thanks for your time.
BrianL2
May 31, 2016NETGEAR Employee Retired
Hi MARKEYBOY,
Does this sub-folder visible in the 'Share' tab in the admin page? Maybe resetting the permission of the 'ReadyNAS_104\Music\Playlists' will help you delete this sub-folder on your PC via Windows File Explorer.
Kind regards,
BrianL
NETGEAR Community Team
MARKEYBOY
Aug 09, 2016Aspirant
Hi. There are no folders whatsoever visible on the Share called 'Music'. If there were, I'm sure I could achieve my goal.
So, any expert advice how to access 'ReadyNAS_104\Music\Playlists' through the Admin Page would be most appreciated. This is bugging me! :(
- BrianL2Aug 09, 2016NETGEAR Employee Retired
Hi MARKEYBOY,
If it's not seen in the admin page, I suspect that this is a a cache on your PC. Could you post a screenshot so we can confirm?
Kind regards,
BrianL
NETGEAR Community Team- MARKEYBOYAug 10, 2016Aspirant
Hi BrianL.
Post a screenshot of what exactly?
Regards
Mark
- BrianL2Aug 10, 2016NETGEAR Employee Retired
Hi MARKEYBOY,
You mentioned that you can see this directory(subfolder) via Window Explorer but it isn't visible in the admin page. We just wanted to confirm and see for ourselves that this directory really exist and if it is, remote or backend access would be needed.
Kind regards,
BrianL
