MARKEYBOY
May 31, 2016Aspirant
Delete corrupt playlist subfolder on RN10400
Hi All. Something bugging me and want to sort it out. I have a ReadyNAS 104 and I want to delete a subfolder of the systems folder called "ReadyNAS_104\Music\Playlists". I can see it in Windows Ex...
- Aug 11, 2016
Success!! Thank you!
IN Windows File Explorer, selected "NAS_VALLEYSIDE" under "Network". Searched for word "Cypress" and it found them. From here the DELETE option is available.
I will now run a re-scan just to finish off. If totally good will mark as an Accepted Solution.
Thanks for your time.
Aug 11, 2016Guru - Experienced User
MARKEYBOY wrote:
OK. I'm understanding what you say about these not being 'real' folders.
SO, did a re-scan as advised.......took a while.........but the phantom playlists still exist as before.
Maybe search \\NAS_valleyside\Music on "Cypress Hill" using explorer's search bar, and see if any playlists come up (anywhere in the share)?? If they do, then delete them and rescan again.
BrianL or another poster might have another suggestion.
MARKEYBOY
Aug 11, 2016Aspirant
