Bent82
Jan 19, 2016Guide
Deleting old home directories
A few years ago I upgraded from an old NV to a 314, OS 6.4.1. I have gotten used to many of the differences, but there is something I still can't figure out how to do. I use AD for users, and every...
- Jan 25, 2016
Hi everyone.
You can't just delete those old home folders because they're btrfs subvolumes.
Though this is not supported by NETGEAR Support, you can remove old home folders with:root@rn314:~# btrfs subvolume list /data | grep home
ID 257 gen 516 top level 5 path home
ID 309 gen 133 top level 257 path home/admin
ID 330 gen 516 top level 257 path home/kohdeeroot@rn314:~# btrfs subvolume delete /data/home/kohdee
Delete subvolume (no-commit): '/data/home/kohdee'
ID 309 gen 133 top level 257 path home/adminBy using SMB to connect to the ReadyNAS as admin, you're exposed to the btrfs subvolumes, but you can't delete; however, this lets you delete files and folders from private home shares to regain your missing space from old home folders.
The subvolumes being there empty hurt nobody. Once you delete the data, the only benefit you get out of deleting the subvolume is for asthetics.
Your subvolume list might be different because you were on a domain. The difference would look like btrfs subvolume delete /data/DOMAIN/USERNAME
Doing this is at your own risk and is not supported by NETGEAR Support.
JennC
Jan 19, 2016NETGEAR Employee Retired
Hello Bent82,
When you map the NAS IP with admin login, you should be able to see a share name Home, this should have all the homes shares of users.
Bent82
Jan 19, 2016Guide
Hi JennC,
I am not sure I exactly have what you are referring to, but let me see. I can log on to the admin webpage of the ReadyNAS, go to the shares tab, and see and browse the home shares. However, I am unable to delete them, right clicking brings up Browse and Copy, but not delete. Current users show up as a folder with a figure of a person on it, while old, deleted users show up as just a folder, but both behave the same way.
I tried accessing the ReadyNAS though SMB, both as the domain\administrator, and as my own user account (also a domain administrator). Neither allow me to see any home share other than my own in the shares list, and neither can access anything like \\ReadyNAS\home.
StephenB, the users I am trying to delete have already been deleted from AD.
