ckj1980
Apr 25, 2016Aspirant
Deleting Snapshots
Hi all, I'm cleaning up a RN2120 and have deleted all shares however there is approx 1.6Tb in use for Snapshots for those folders I just deleted. How do I clear this off? Will a SCRUB rem...
- Apr 26, 2016
From your problem description it sounds like most likely you created your volume on very old firmware, which is why I liked the idea of destroying the volume and creating a new one (or even doing a factory reset - wipes all data, settings, everything).
mdgm-ntgr
Apr 26, 2016NETGEAR Employee Retired
If you've deleted all the shares you may as well delete the volume (destroying any remaining data on that) as well and create a new volume.
- StephenBApr 26, 2016Guru - Experienced User
I agree, but wanted to add that you should install your apps first, and reinstall after you create a new volume.
