ckj1980
Apr 25, 2016Aspirant
Deleting Snapshots
Hi all, I'm cleaning up a RN2120 and have deleted all shares however there is approx 1.6Tb in use for Snapshots for those folders I just deleted. How do I clear this off? Will a SCRUB rem...
- Apr 26, 2016
From your problem description it sounds like most likely you created your volume on very old firmware, which is why I liked the idea of destroying the volume and creating a new one (or even doing a factory reset - wipes all data, settings, everything).
ckj1980
Apr 26, 2016Aspirant
I did consider doing that however there is a couple of very larger (5Tb+) folders with backup data in them which means I can't destroy the volume and start again.
Any other suggestions on how I can get this space back?
mdgm-ntgr
Apr 26, 2016NETGEAR Employee Retired
So you didn't delete all the folders/shares on the volume then.
Perhaps send me your logs (see the Sending Logs link in my sig).
