Leofwine
Dec 24, 2014Tutor
Deleting Time Machine sparsebundle
I just started using my new RN102 and had no difficulty configuring Time Machine but unfortunately, after backing up about 300GB of 450GB there was an interruption in the connection for some reason (...
mdgm-ntgr
Dec 24, 2014NETGEAR Employee Retired
Go to https://[ReadyNAS]/admin/browse.html#path=%2F[volume]%2F.timemachine
Where [ReadyNAS] is the I.P. address of the NAS and [volume] is the name of your data volume
You should then be able to select the sparsebundle and delete it.
